404 (NOT FOUND) as sending request for /reports/<id>/content
Posted by: sonnguyentruong87 on 16 December 2019, 1:12 am EST
    Posted 16 December 2019, 1:12 am EST
    I am implementing web designer.
    for Owin Startup, I added in 2 lines
     app.UseReporting(configure => configure.UseFileStore(ResourcesRootDirectory));
                app.UseDesigner(config => config.UseFileStore(ResourcesRootDirectory, false));
    I got error NOT FOUND on getting report contents. While /reports/list
    words fine.
    Did I missed something ?
  • Posted 16 December 2019, 1:15 am EST
    Sorry for the typo.
    works fine.
  • Posted 16 December 2019, 7:05 am EST
    Please try after adding the following line <system.webServer> section
    <security>
        <requestFiltering allowDoubleEscaping="true"/>
      </security>
    Hope it helps.
  • Posted 16 December 2019, 8:04 am EST
    Thank you for the support,
    Do we have to call ```
    encodeURIComponent
    on reportId at front-end (javascript) ?.
  • Posted 16 December 2019, 8:08 am EST
    No, Just add the previously mentioned lines in WebConfig. It will solve your issue.
    Request to please confirm is issue still reproducible at your end after adding mentioned lines.
  • Posted 16 December 2019, 11:10 pm EST
    Hi mohitg,
    It does not work either, NOT FOUND persists. on my webform application. I added into config tag system.webServer.
  • Posted 17 December 2019, 2:19 am EST
    Could you please share your application so that I can replicate the issue at my end. Also, WebDesigner backend depends on MVC. So you can’t use the WebDesigner in simple WebForm application(Asp.Net).
