Posted 28 September 2017, 11:22 am EST
My company is using ActiveReports v10. Some reports are failing and the Event Viewer records the error as:
<Exception>
<Description>
A generic error occurred in GDI+.
</Description>
<Source>
System.Drawing
</Source>
<Method>
Void Save(System.IO.Stream, System.Drawing.Imaging.ImageCodecInfo, System.Drawing.Imaging.EncoderParameters)
</Method>
<Stack>
at System.Drawing.Image.Save(Stream stream, ImageCodecInfo encoder, EncoderParameters encoderParams)
at #Xkc.#Hpc.#Uuc(Image image, ImageFormat format)
at #qSr.#tKg.#hg(Image image, ImageFormat imageFormat, Boolean withoutImageMark)
at #qSr.#tKg.#hg(Image image, ImageFormat imageFormat, Boolean withoutImageMark, String key)
at GrapeCity.ActiveReports.Export.Pdf.Page.Core.PdfDrawingCanvas.#U.#Ync..ctor(Image image, Boolean isPdfA1, String cacheId)
at GrapeCity.ActiveReports.Export.Pdf.Page.Core.PdfDrawingCanvas.CreateImage(Image image, String cacheId)
at #HyA.#Y4e.#3Bf(IGraphicsRenderContext context, ILayoutArea area)
at #pSr.#brc.RenderReportItem(ILayoutArea area)
at #HyA.#Y4e.#1Bf(IGraphicsRenderContext context, ILayoutArea area)
at #HyA.#Y4e.#0Bf(IGraphicsRenderContext context, ILayoutArea area)
at #pSr.#lV.#ROf(ILayoutArea section)
at #pSr.#lV.#1Db(ILayoutPage page)
at GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension.#DSg(IDrawingCanvas canvas, Int32 pageIndex, TargetDeviceKind device)
at GrapeCity.ActiveReports.Export.Image.Page.PageController.PageController.RenderPhysicalPage(Int32 physicalPageIndex, Int32 pageCount, IDrawingCanvas canvas, RectangleF pageSize, RectangleF reportPageSize, IReport report, TargetDeviceKind device)
at GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension.Render(IReport report, StreamProvider streams, NameValueCollection settings)
at GrapeCity.ActiveReports.Document.PageDocument.Render(IRenderingExtension renderingExtension, StreamProvider streams, NameValueCollection settings, Boolean forceDataRefresh, Boolean forceParameterDataRefresh)
</Stack>
</Exception>
Has anyone else run into this issue? Please let me know. Thanks.
