Posted 18 February 2019, 7:46 am EST - Updated 30 September 2022, 3:49 pm EST
ActiReports 13 Installation Rollback
Posted by: s.canyelles on 18 February 2019, 7:46 am EST
Posted 20 February 2019, 2:02 am EST
Please share the log file with us so that we can narrow down the issue at our end.
Also, you can refer to the following link to create the install log manually.
https://www.advancedinstaller.com/user-guide/qa-log.htmlThanks,
Posted 20 February 2019, 4:35 am EST
Hi Mohitg,
Thanks for the response.
Here you have the log.
Apparently the error is extracting to a temporary directory :
SFXCA: Failed to extract to temporary directory. Cabinet error code 11.
CustomAction SaveInstallationDate returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
02/20/2019 09:24:49.841 [18428]: Assembly Install: Failing with hr=80070005 at RemoveDirectoryAndChildren, line 39302/20/2019 09:24:49.857 [18428]: Detailed info about C:\Windows\assembly\tmp\6N1T9V8K\GrapeCity.ActiveReports.Interop.dll
02/20/2019 09:24:49.857 [18428]: File attributes: 00000020
02/20/2019 09:24:49.982 [18428]: Restart Manager Info: 1 entries
02/20/2019 09:24:49.982 [18428]: App[0]: (18428) Windows Installer (msiserver), type = 1000
02/20/2019 09:24:49.982 [18428]: Security info:
02/20/2019 09:24:49.982 [18428]: Owner: S-1-5-32-544
02/20/2019 09:24:49.982 [18428]: Group: S-1-5-18
02/20/2019 09:24:49.982 [18428]: DACL information: 5 entries:
02/20/2019 09:24:49.982 [18428]: ACE[0]: Type = 0x00, Flags = 010, Mask = 001f01ff, SID = S-1-5-18
02/20/2019 09:24:49.982 [18428]: ACE[1]: Type = 0x00, Flags = 010, Mask = 001f01ff, SID = S-1-5-32-544
02/20/2019 09:24:49.982 [18428]: ACE[2]: Type = 0x00, Flags = 010, Mask = 001200a9, SID = S-1-5-32-545
02/20/2019 09:24:49.982 [18428]: ACE[3]: Type = 0x00, Flags = 010, Mask = 001200a9, SID = S-1-15-2-1
02/20/2019 09:24:49.982 [18428]: ACE[4]: Type = 0x00, Flags = 010, Mask = 001200a9, SID = S-1-15-2-2
Thanks!
Posted 21 February 2019, 2:29 am EST
Could you please try to install AR13 with the admin privileges? Also, please try after turning off UAC in the system.
If the problem still occurs, please share the full log file of the installer.
Posted 21 February 2019, 8:37 am EST
I did it with the same result.
Find attached the log.
Thanks & Regards.
Posted 21 February 2019, 9:32 am EST
Could you please attach the log file in Zip format.
Posted 22 February 2019, 5:42 am EST
Done!
Posted 22 February 2019, 6:08 am EST
It seems that still, file is not attached properly. Could you please upload at the following link:https://www.dropbox.com/request/pprgRUGcO6evALDBlZUj
Posted 22 February 2019, 7:33 am EST
Done, uploaded to dropbox
Posted 22 February 2019, 8:41 am EST
Could you please confirm the following things:
1: Please try to install without the sample.
2: Please try after disabling the antivirus of your system.
3: Is there any other version of AR is present in your system(Like AR12 or AR11).
4: Could you please try to install the License manager explicitly, so that we can narrow down the issue. Please share the log file If setup failed. If not, please try to install the AR after installing the License Manager
5: Please share the full environment detail(Including OS Version, bit, Number and name of Visual studio, antivirus name)
6: Also, please share the event viewer message.Thanks.
Posted 25 February 2019, 5:54 am EST
Thanks Mohitg,
Problem solved.
It was the antivirus.
Regards.
Posted 25 February 2019, 5:57 am EST
I am glad that your issue has resolved now. Please feel free to revert if you have any question further.
