Posted 8 June 2023, 1:06 pm EST
I had an old legacy system with an Active Report that was running v6.2.3164.0 originally with Visual Studio 2010. This old system doesn’t work anymore and I am trying to bring this report over into a newer solution.
I have AR 15.2.3 installed and I was able to add references, recreate the report and it loads in the designer and looks right, and I got everything to compile, but I get an error when I try to run it: “Could not load file or assembly ‘System.Buffers, Version=4.0.2.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’ or one of its dependencies.”
This happens on the pdf.Export() line below:
using (var pdf = new GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport())
using (var rpt = new rptReleaseNotes())
rpt.DataSource = dtSource;
rpt.DataMember = "NOTES";
rpt.Document.Printer.PrinterName = "";
rpt.Run(false);
string strFile = ddlFixFor.SelectedItem.Text.Replace("Version ", "v") + " - ALL.pdf";
lstFiles.Add(strFile);
pdf.Export(rpt.Document, Context.Server.MapPath(Context.Request.ApplicationPath) + @"\ReleaseNotes\" + strFile);
// ERROR happens on the line above:
// Could not load file or assembly 'System.Buffers, Version=4.0.2.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
My packages.config file has:
<package id="System.Buffers" version="4.5.1" targetFramework="net472" />
I tried putting this in my web.config file:
<assemblyBinding>
<dependentAssembly>
<assemblyIdentity name="System.Buffers" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.5.1.0" newVersion="4.5.1.0" />
</dependentAssembly>
</assemblyBinding>
…but then the page won’t even render at all, I get an immediate YSOD when I try to load it. I have attached my .csproj file - any idea what I’m doing wrong?
