Posted 10 January 2022, 10:10 am EST
Hello.
I have found this piece of code :
using (var reportStream GetType().Assembly.GetManifestResourceStream("RuntimeDataBinding.CallCenterPerformace.rdlx"))
using (var reader = new System.IO.StreamReader(reportStream))
var rpt = new GrapeCity.ActiveReports.PageReport(reader);
var pdfRe = new GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
var output = new GrapeCity.ActiveReports.Rendering.IO.MemoryStreamProvider();
rpt.Document.LocateDataSource += (sender, args) =>
args.Data = dataLayer.GetPerformanceData(startDate, endDate);
rpt.Document.Render(pdfRe, output);
return output.GetPrimaryStream().OpenStream();
Based on that my question would be : What would I need to return(Instead of a PDF rendered stream) to my Angular UI in order to render it with my JSViewer?
Thank you in advance.
Ch.E
