Posted 8 November 2024, 6:48 am EST
When changing the language of a report, the report designer (Windows) will create Localization Resources inside the report, for the chosen language. This doesn’t work in web designer, although I can change the report language, this setting has no effect, and will overwrite the default values.
Reporduce:
- Create a report with a text field and name it “Hello” (Language: Default)
- Change the report language to French-France and change the text to “Bonjour”
- Switch back to “Default”, you will see “Hello” and vice versa.
In Report web-designer:
4. Change the report language to French-France and change the text to “Au revoir” and save the report.
5. Open the report in French-France, the Text remains “Bonjour” but now the default Value is “Au revoir”.
This is a bug. The web designer should behave as the windows designer does. When a language in the report is chosen, I only should edit the localization values of the chosen language
