Posted 3 November 2018, 3:57 pm EST
I’m doing an evaluation regrading moving over from AR6 to AR12. Over the years we have developed a ton of reports so avoiding having to go through a significant conversion is essential.
I modified our existing end user Report Designer. Using AR12 section reporting. It seemed to be working just fine. All our RPX files worked, the reports produced by AR6 and AR12 have so far come out identically. But, when working with the report data sources we use I encountered a significant issue. In * "AR6 "
if I use a query like:
SELECT c., s. FROM tblContract c, tblLinkContractStatus s WHERE c.ContractID = s.ContractID
The bound fields all display.
But, in AR12 the same query generates the error:
ERROR: The Data Source has duplicate fields: ContractID
Ok so why are we now seeing this error and is it possible to circumvent? I have noticed that if you drop a text box on the designer the “Data Field” drop down list all the columns correctly. I have also noticed existing reports still run even with this same error condition.
- “This is no small issue.”
because it undermines a lot of work already done and in circulation.
For whatever reason it’s much simpler to join tables then having to identify just the columns used, at least for the non-technical users. I tried using the Query Tool provided but without the intelisense [sic] it’s not a very helpful tool. In addition the Query Tool Database view does not list table-valued function which we use.
Any help will be appreciated
