Build agent licensing issues
Posted by: developersupport on 17 May 2021, 12:13 pm EST
  • Posted 17 May 2021, 12:13 pm EST
    We are using GitHub Actions to build and publish our projects and even when calling
    gclm "e88c1aa3-2781-44bb-b639-765c9ef6d15c" -d
    after every build and getting a deactivation confirmation we still get licensing errors everyone once in a while saying ```
    The usage of this serial key has been exceed the limit.
    Is there something we're missing?
  • Posted 18 May 2021, 12:38 am EST
    Can you please confirm the following thing:
    1: You have same server to build every project or different server for different project?
    2: On how many machine, key is activated currently?
    3: Are you facing this issue continuously or once in while?
    4: Can you make sure that key is activated on three machine machine maximum(including dev, test and server machine).
  • Posted 18 May 2021, 10:02 am EST
    1. It’s a different server every time. We are using GitHub actions with their hosted runners
    2. Currently there is 1 machine activated
    3. This only happens every once in a while, but when it does we don’t have a great way of catching it
    4. The key is only activated on 1 dev machine, then during our CI build we activate the build agent, run the build, then deactivate the build agent so it should no longer be activated
  • Posted 18 May 2021, 10:12 am EST
    Is there any chance, you build different project on different server simultaneously which exceed the maximum activation of the key?
  • Posted 18 May 2021, 11:53 am EST
    This is the only project we are using ActiveReports in. The last time we got this error it was the only build that we ran within a 10 hour span that wouldn’t activate, so it’s not like we were running builds over and over again.
  • Posted 19 May 2021, 1:01 am EST
    “The usage of this serial key has been exceed the limit.” error occurs only when there is more than 3 activation of the key on the different machine. Can you please at your end, is there any time when key activated more than 3 time.
  • Posted 20 May 2021, 10:12 am EST
    Since we activate and deactivate it on every build I’m sure it’s been activated on multiple machines, but it should only be activated on each build machine for a few minutes. That seems like a pretty common pattern for modern CI/CD usage, is that really not supported?
  • Posted 20 May 2021, 1:48 pm EST
    Actually, as per AR license specification, key can only activate on three machine at a time. If in your build process, same key is activated more than 3 time at a time then you will receive error message while activating the key on 4th time.
