Can't add ActiveReport (19) to website project in VS2022
Posted by: law on 24 March 2025, 3:21 pm EST
  • Posted 24 March 2025, 3:21 pm EST - Updated 24 March 2025, 3:26 pm EST
    As the title says, I’ve installed (and activated) AR19 on my computer, opened VS2022, file → open → web site and opened a site that happens to be on the local machine (but tried on a remote server too with same result).
    When I right-click the site in the solution explorer, choose “add → add new item”, no ActiveReports options appear. Am I doing something wrong? I’ve been a bit out of touch with AR in recent years but with AR13 and VS2017 this worked fine.
  • Posted 26 March 2025, 8:11 am EST
    Please make sure the ActiveReports 19 extension is installed properly. You can download it from the following link: ActiveReports 19 VS2022
    If the issue persists then please make sure the project you are using is mentioned in the Supported Environments: Product requirements
    I hope this helps!
  • Posted 26 March 2025, 1:44 pm EST
    I think I meet all the requirements? Machine is Windows 11, .NET framework 4.8.1 is installed along with the associated .NET framework and Windows SDKs, and I’m using Visual Studio 2022.
    When I run the installer for the extension, it says “This extension is already installed to all applicable products.”
  • Posted 27 March 2025, 8:16 am EST
    Hi Eric,
    Based on your previous case it seems that you are using Web Site application(Legacy). I was able to reproduce this issue with the Legacy Project template. I have reported this issue to the development team[AR-35476].
    I will get back to you once I have any updates on the same.
