Posted 27 August 2020, 2:41 am EST
Hello Kim,
I am sorry for the inconvenience caused.
VS 2019 came in the market after the last release of AR11. It was neither designed nor tested to be used with VS 2019. That’s why, AR11 does not support VS2019.
Note that, AR11 is a legacy product. It is out of maintenance mode now. Hence, we do not fix any bug for the product and also, do not provide support for the same. As per our policy, we don’t extend environment support to older versions. Therefore, you would need to upgrade to the latest version, i.e, AR14 in order to be able to use the modern tools and environments.
However, you can use AR11 dlls in VS0219 and code but the AR templates would not be available for VS0219.
You can refer to the following link for supported versions of VS in AR11:
https://help.grapecity.com/activereports/webhelp/AR11/webframe.html#Requirements.html
Once again, I am sorry for not being able to help much in this case.
