Connect Web Designer to SQL Server
Posted by: gci on 20 April 2020, 11:22 am EST
    Posted 20 April 2020, 11:22 am EST
    I need to connect a report to sql server. I see that within available providers I have “Microsoft SQL Client Provider” but I got an error when testing the connection. Is this normal o do I have to add custom code in order for this to work ?
  • Posted 21 April 2020, 2:34 am EST
    I am able to connect the MS SQL server through the WebDesigner. Could you please share the error message that you’re facing while connecting the MsSql server.
  • Posted 21 April 2020, 9:16 am EST - Updated 30 September 2022, 3:37 pm EST
    I followed the example here: https://www.grapecity.com/activereports/docs/v14/online/how-to-create-simple-web-designer-sample.html
    Whe I try to connect to SQL, I got the attached error.
  • Posted 22 April 2020, 3:53 am EST
    Could you please refer the following sample to check at your end:
    https://github.com/activereports/WebSamples14/tree/master/WebDesignerSamples
    If the issue is still reproducible, could you please share the sample with me.
  • Posted 22 April 2020, 10:05 am EST - Updated 30 September 2022, 3:37 pm EST
    Hi
    I’ve checked these examples. The MVC project seems to work as expected. I could connect to my data source and run a few reports.
    On the other hand, MVC-Core one (which I could be interested in implementing) shows a license error when run it. I’ve seen this error in one of the posts and included the licx file within properties folder but it still does not work. Images attached:
  • Posted 22 April 2020, 10:36 am EST
    Could you please run your application in VS2019 as AR support .Net core only in VS2019.
