Posted 3 May 2021, 3:06 pm EST
I am using a software called Mastercam it allows me to program CNC machines, now this software came with a dumbed-down version of Active Reports. This allows me to create set-up sheets so my operators know how I programmed the part and how to set up the machine. Now, I want to be able to create a “field input” so when the file is saved as a pdf, the operators can view and add notes to the set-up sheet easily. That being said, the version of ActiveReports that came with my software does not have the “Field Input” function baked in. Is there a way to go about using the scripting to add a field input?
