Posted 26 January 2021, 10:43 am EST
Hi Team,
I see that when click save in report designer and it calls to api :
http://localhost:58721/api/reports/content?name=Untitleds.rdlx
Can I customize it ?
Duc Nguyen
Forums Home / ActiveReports / General Discussion
Posted by: ducn on 26 January 2021, 10:43 am EST
Hi Team,
Duc Nguyen
Posted 26 January 2021, 11:31 pm EST
Could you please share the Use case and requirement to customize the service?
Posted 28 January 2021, 4:04 am EST
At the report designer : I don’t want to return :
At the Report Viewer : Can I modify at the runtime for mapping DatasourceID, DatasetID
Duc Nguyen
Posted 1 February 2021, 11:24 am EST
You can add the dataset in the WebDesigner by adding the Dataset file “WebDesigner_MVC\datasets” folder. You can refer the attachment for the sample JSON file. Also, you can show the custom dataset names via public object GetDataSetsList() and create(or load pre-created) datasets in public object GetDataSet(string id). Please refer to the attached sample Json.
After that, you can use the SetLocateDataSource method of reporting service to the return the datatable at runtime.
settings.SetLocateDataSource(args =>
return new DataTable();
