Customize pivot panel checkbox
Posted by: spathi on 24 February 2020, 9:41 am EST
    Posted 24 February 2020, 9:41 am EST - Updated 30 September 2022, 3:38 pm EST
    after implementing customize pivot panel if i click on the checkbox , flickering is happening. and also on resize of the window the original custom boxes are appearing instead of the customized one.
  • Posted 25 February 2020, 5:25 am EST
    Hello Spathi,
    To investigate this we need a stripped-down sample of your application replicating the issue with all the clear steps that need to be taken for this.
  • Posted 28 February 2020, 3:33 am EST
    http://jsfiddle.net/rykygo6t/ check this demo,
    Click one of the checkbox see the behavior.
    and also check resize the window how it’s behaviors.
    i want custom check boxes like before post instead of pivot panel check boxes.
  • Posted 6 March 2020, 3:22 am EST
    Hi Spathi,
    Sorry for the delayed response.
    Instead of adding the checkboxes in the on window resize, you can use the formatItem event of the FlexGrid. The fields that you wish to customize are made using a FlexGrid. In the formatItem, add your custom checkbox and add an event listener on this checkbox to set the fields as active or not.
    Please refer to the sample attached.
    Similarly, you can also customize the layout for the row fields, column fields, etc.
    pivot panel customize.zip
  • Posted 19 March 2020, 3:06 am EST
    Hi Ashwin,
    can you implement the same in angular 8.
  • Posted 20 March 2020, 2:34 am EST
    Please refer to the sample attached that implements the same behavior in Angular 8.
    Also, can you please post all the queries related to Wijmo on the Wijmo’s forum:
    https://www.grapecity.com/forums/wijmo
    pivot panel.zip
  • Posted 23 March 2020, 4:18 am EST
    the given sample not working in angular 8
  • Posted 23 March 2020, 4:31 am EST
    Is there any error shown in the console?
  • Posted 2 April 2020, 4:37 am EST - Updated 30 September 2022, 3:38 pm EST
    yes it showing fromatitem is not exist
  • Posted 3 April 2020, 5:04 am EST
    Can you modify the above sample so that it replicates the issue? Also, please provide us with the Wijmo’s version that you are using as well as the screenshot of the error.
