Posted 14 November 2024, 7:48 pm EST - Updated 14 November 2024, 7:50 pm EST
I have upgraded a console app from .net framework 4.7 to .net8
The project includes a licenses.licx. When the file is empty the project is build successfuly (using VS2022) but as soon the file has the same content it had when compiled for .net framework a compile time error occurs.
Below is the license.licx content and the error produced:
GrapeCity.ActiveReports.SectionReport, MESCIUS.ActiveReports
GrapeCity.ActiveReports.PageReport, MESCIUS.ActiveReports
Severity Code Description Project File Line Suppression State
Error (active) LC0000 'Could not load file or assembly 'System.Runtime, Version=4.2.2.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Reference assemblies should not be loaded for execution. They can only be loaded in the Reflection-only loader context. (Exception from HRESULT: 0x80131058)' PrintJobProcessor E:\source\PrintJobProcessor\LC 1
I have removed the file and the content back and forth several times so I’m sure this is causing such error, what is the cause? or better what is the proper way to license such command line app?
