Get Parameters "HasOutstandingDependencies"
Posted by: andy.beaulieu on 19 November 2018, 4:43 pm EST
    Posted 19 November 2018, 4:43 pm EST
    I would like to get all of the Parameters for a Report including the AvailableValues.
    So, I call the REST method /api/reports/{id}/parameters
    However, some of the Parameters come back with State=“HasOutstandingDependencies” (since they are dependent on some of the other parameters in their DataSource).
    How can I get all of the Parameters with AvailableValues for a Report? Is there any way to request Parameters and pass in the dependent parameter values?
  • Posted 20 November 2018, 2:31 am EST
    You can use the “POST” command (/api/reports/{id}/parameters/validateValues) to get report parameter after passing the required parameter value like below:
    “Name”: “ReportParameter”,
    “Domain”: “SpecifiedValues”,
    “Values”: [
    “Rock”
    “Name”: “ReportParameter1”,
    “Values”: [
    “Accept”
    Also, you can refer to the following link:
    http://help.grapecity.com/activereports/webhelp/AR12ServerAPI/index.html#!/reports/post_api_reports_id_parameters_validateValues
    Hope it helps.
  • Posted 20 November 2018, 11:37 am EST
    Thanks, that was it!
