Got issue on Webviewer for Version 14.1
Posted by: tsysysy on 14 June 2020, 9:45 pm EST
    Posted 14 June 2020, 9:45 pm EST - Updated 30 September 2022, 3:35 pm EST
    i got issue on version 14 the webviewer.
    i got one screen with the filter for my report
     Dim rpx As New SectionReport
                        Dim ds As New DataSet()
                        Dim xtr As New System.Xml.XmlTextReader(Server.MapPath("~") & "\_Templates\Ar\Tms_TimeSheet.rpx")
                        ssql = "Exec sp_tms_SelRptTimeSheet """ & Session("Company").ToString & """,""" & myDS.Tables(0).Rows(0).Item(1).ToString & """,""" & myDS.Tables(0).Rows(0).Item(2).ToString & """,""" & ddlOPTION_GROUP.SelectedValue & """,""" & spid & """,""" & Session("EmpID").ToString & """"
                        ds = mySQL.ExecuteSQL(ssql)
                        rpx.LoadLayout(xtr)
                        rpx.DataSource = ds.Tables(0)
                        Session("rptGenericReport") = Nothing
                        Session("rptGenericReport") = rpx
                        myTargetURL = "../../ReportViewer.aspx"
                        Response.Redirect(myTargetURL)
                        xtr.Close()
    then pass the sectionreport to the webviewer page
    Imports GrapeCity.ActiveReports
    Imports GrapeCity.ActiveReports.Extensibility
    Partial Class ReportViewer
        Inherits System.Web.UI.Page
        Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
            If Page.IsPostBack = False Then
                Dim viewprinter As New GrapeCity.ActiveReports.Extensibility.Printing.Printer()
                viewprinter.PrinterName = ""
                WebViewer1.ViewerType = GrapeCity.ActiveReports.Web.ViewerType.HtmlViewer
                WebViewer1.Report = CType(Session("rptGenericReport"), SectionReport)
            End If
        End Sub
    End Class
    but got below error. the script was working fine on version 12.
  • Posted 15 June 2020, 3:24 am EST
    This issue is fixed in the latest version of AR14. Could you please try with the latest version You can download the same from the following link:
    https://www.grapecity.com/activereports/download
  • Posted 15 June 2020, 9:40 pm EST
    my activereport version was 14.1.19970, i was using trail version. because i need to make sure this can be work.
    the nuget i install also Grapecity.activereport version 14.1.19970
    the GrapeCity.activereport.web i install version 14.1.2117
    is that got issue.
    is that got new version? because at nuget this was the newest version already.
  • Posted 16 June 2020, 7:40 am EST
    Yes, it is the latest package. Could you please try with the attached application.
    If issue is not reproducible with the attached application, please modify the attached one or share the stripped-down sample so that I can reproduce the issue at my end.
    WebViewerApplication1 (2).zip
  • Posted 17 June 2020, 4:43 am EST
    this sample was can view the report.
    can you list down what i need to install from nuget to get my application working.
    now i only install Grapecity.ActiveReports and Grapecity.ActiveReports.Web
  • Posted 18 June 2020, 2:04 am EST
    Can try after adding the following package:
    If issue is still reproducible, then try after adding the following package
    GrapeCity.ActiveReports.Web.Design
    Hope it helps.
  • Posted 18 June 2020, 2:18 am EST - Updated 30 September 2022, 3:35 pm EST
    helllo,
    when install the GrapeCity.ActiveReports.Web the Web.viewer and Web.Design already been install.
  • Posted 18 June 2020, 3:01 am EST
    There is no extra package needed to run the report in WebViewer. Can you please share the sample so that I can replicate the issue at my end.
