Posted 18 April 2024, 1:17 pm EST
Hi. I’m trying to localize an rdlx report to French. This looks like it should be as simple as setting the language property on the report to French (Canada), changing the text, and then running it with the thread’s culture/UI culture set to French (Canada). That works great at design time. At run time I just get the default text no matter what.
Is there a step I’m missing? The documentation for AR 18 seems to be entirely devoid on how to do this (the localization topic is about localizing AR itself, but doesn’t talk about reports), but older versions had documentation on the subject and suggest this should work: https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#LocalizeActiveReportClassesTextBoxesandChartControls.html
