How to bind a field in the report with an object of a class
Posted by: snehajose1990 on 23 September 2019, 7:53 am EST
    Posted 23 September 2019, 7:53 am EST - Updated 30 September 2022, 3:44 pm EST
    I have an old report where the datafield property of the fields is assigned to property of a class. e.g. in the report one of the fields data field property is : =myclass.itemID.
    Programmatically how can we declare the object of the class so that the report will identify the object directly and assign its property value. I tried to use AddNamedItem method but that doesn’t work. How can we fetch the values in such scenario.
    Your help will be highly appreciated.
  • Posted 23 September 2019, 8:16 am EST - Updated 30 September 2022, 3:44 pm EST
    Hello Sneha,
    Please write the following code in script of the report to access the variable of the class instead of in “DataField” property;
    public void Detail_Format()
    	this.TextBox1.Text = myclass.itemId;
    Pelase refer to the attached image for more clarification.
    Hope it helps.
  • Posted 23 September 2019, 8:47 am EST
    Hi Mohit,
    Thanks for your reply.
    Actually I have around 140 reports existing in our application which of version AR2 and we are migrating to AR13 . All the reports already have datafield property which is set to class property. we do not want to make any changes in these reports but want to handle it in the code. Is there a way this can be achieved.
  • Posted 24 September 2019, 1:43 am EST
    Hi Mohit,
    Any update??
  • Posted 24 September 2019, 2:37 am EST
    You can use the following line on code to set the value of the TextBox if you don’t want to edit the report.
    public Form1()
                InitializeComponent();
                GrapeCity.ActiveReports.SectionReport sectionReport = new GrapeCity.ActiveReports.SectionReport();
                System.Xml.XmlTextReader xtr = new System.Xml.XmlTextReader(@"..\..\SectionReport1.rpx");
                sectionReport.LoadLayout(xtr);
                xtr.Close();
                viewer1.LoadDocument(sectionReport);
                sectionReport.Sections["Detail"].Format += Form1_Format;
            private void Form1_Format(object sender, EventArgs e)
                GrapeCity.ActiveReports.SectionReportModel.Detail detail = (GrapeCity.ActiveReports.SectionReportModel.Detail)sender;
                (detail.Controls["TextBox1"] as GrapeCity.ActiveReports.SectionReportModel.TextBox).Text = test.itemId;
    Hope it helps.
