Insert subreports programmatically
Posted by: edv on 30 April 2020, 5:56 am EST
    Posted 30 April 2020, 5:56 am EST
    Hi!
    I am using a licensed Version of ActiveReports 11. I am using also Section Report (Cade based):
    In the Detail_Format section I’ve defined the following:
    Dim _SubReport As arSubRerpot = Nothing
    Where arSubRerpot is an external report, that is in the design time three times inserted under the names arSubRerpot1, arSubRerpot2, arSubRerpot3
    The used Code looks like this:
    Dim dt As DataTable ….
    Dim i As Integer
    For Each dr As DataRow In dt.Rows
    	Select Case i
    	Case 1
    		arSubRerpot1.Report = New arSubRerpot
    		_SubReport = arSubRerpot1.Report
    	Case 2
    		arSubRerpot2.Report = New arSubRerpot
    		_SubReport = arSubRerpot2.Report
    	Case 3
    		arSubRerpot3.Report = New arSubRerpot
    		_SubReport = arSubRerpot3.Report
    	End Select
    	SubReport = Nothing
    	I += 1
    Next
    This works fine!
    Now I am having the problem, that the number of subreports is undefined, it may be 1 or 10 …
    I am looking for a way to add the subreports programmatically and not in the design time.
    Thank you in advance
  • Posted 4 May 2020, 3:57 am EST
    You can add as much SubReport Control in the report in “Report_Start” event as follow:
    Private Sub Report_PageStart(ByVal sender As Object, ByVal e As EventArgs)
        Dim subcontrol1 As GrapeCity.ActiveReports.SectionReportModel.SubReport = New GrapeCity.ActiveReports.SectionReportModel.SubReport()
        Me.detail.Controls.Add(subcontrol1)
    End Sub
  • Posted 4 May 2020, 5:50 am EST
    Thank You Mohit.
    So I can add a subreport in “Report_Start”. But How can I use it in the “Detail_Format”?
    “subcontrol1” is not declared there!
    Trying something like “Me.Detail.Controls(“subcontrol1”)…” does no work too. The control ist not recognized as a subreport.
    I’ve tried in “Report_Start” something like;
    srTermDetail5.Name = “subcontrol1”
    or/and srTermDetail5.ReportName = “subcontrol1”
    But no chance!
    What’s I am doing wrong?
  • Posted 4 May 2020, 5:51 am EST
    Sorry I mean:
    subcontrol1.Name = “subcontrol1”
    or/and subcontrol1.ReportName = “subcontrol1”
  • Posted 4 May 2020, 5:58 am EST
    You can typecast the control as follow:
    Ctype(Me.Detail.Controls(“test”), GrapeCity.ActiveReports.SectionReportModel.SubReport).ReportName=“”
  • Posted 4 May 2020, 6:59 am EST
    Sorry but it does not work.
    “subcontrol1” is still not declared in “Detail_Format”.
  • Posted 5 May 2020, 3:21 am EST
    Please refer to the attached sample. If the issue still occurs, please modify the attached sample and give back to us.
    win_SubReport.zip
  • Posted 6 May 2020, 6:37 am EST
    You can set the Left, TOp of the subreport control as follow:
        Me.SubReport1.Height = 1.0!
        Me.SubReport1.Left = 0!
        Me.SubReport1.Top = 0!
        Me.SubReport1.Width = 3.0!
        Me.Detail.Controls.Add(subcontrol1)
        Dim subcontrol2 As GrapeCity.ActiveReports.SectionReportModel.SubReport = New GrapeCity.ActiveReports.SectionReportModel.SubReport()
        subcontrol2.Name = "subcontrol2"
        Me.SubReport2.Height = 1.0!
        Me.SubReport2.Left = 0!
        Me.SubReport2.Top = 1.0!
        Me.SubReport2.Width = 3.0!
        Me.Detail.Controls.Add(subcontrol2)
  • Posted 6 May 2020, 7:22 am EST
    Super!
    What does “!” means?
  • Posted 6 May 2020, 7:32 am EST
    It is the syntax to assign the value to size/location properties control of SectionReport.
  • Posted 6 May 2020, 7:51 am EST
    Thank you very much.
  • Posted 6 May 2020, 8:39 am EST
    Sorry I have another question:
    I would like to add n subreports, where n is only known in runtime !
    something like that:
    for i = 1 to n
    ' Add sub report i
    next i
    Is there is a way to do this?
    Dim subcontrol(i) As GrapeCity.ActiveReports.SectionReportModel.SubReport = New GrapeCity.ActiveReports.SectionReportModel.SubReport()
            subcontrol(i).Name = "subcontrol" & i
    An array of controls?
  • Posted 7 May 2020, 1:21 am EST
    You can use the following line of code:
    For I As Integer = 0 To N
               Dim subcontrol As GrapeCity.ActiveReports.SectionReportModel.SubReport = New GrapeCity.ActiveReports.SectionReportModel.SubReport()
               subcontrol.Name = "subcontrol" + I.ToString()
               Me.Detail.Controls.Add(subcontrol)
           Next
    After that, you can access the subcontrol in the detial section through its name.
  • Posted 7 May 2020, 4:18 am EST
    Thank you very much for the super support.
  • Posted 19 May 2020, 3:08 am EST
    Thank you very much Mohit. It works!
    tubemate mobdro
