Issue with inserting page(s)
Posted by: p.feenstra on 20 January 2022, 6:57 am EST
    Posted 20 January 2022, 6:57 am EST
    Using AR15 SectionReports
    Inserting or adding a page programmatically no longer works and results in an error.
    My previous AR10 did not have any problems with that.
    Am I missing a reference or have I found a bug again?
    Regards Piet
  • Posted 23 January 2022, 1:17 pm EST
    Invested a little more time in the problem.
    It seems that AR15 does not recognizes a report as an object anymore. AR10 does.
    But luckily it does recognize a PagesCollection as an object.
    So with a workaround it could be fixed.
    This bug will be easy to fix for the developers. (I hope they do)
    Regards Piet
  • Posted 24 January 2022, 7:32 am EST
    To insert a new page within a report in Active Reports 15, you may use the Pages property and may insert a new instance of Page Class within the ReportEnd event to implement the same. Please refer to the below code snippet:
     private void SectionReport1_ReportEnd(object sender, EventArgs e)
                var pageCount = this.Document.Pages.Count;
                this.Document.Pages.Insert(pageCount , new GrapeCity.ActiveReports.Document.Section.Page());
    Please refer to the sample attached below.
    Dushyant Sharma
    SectionReport_Parameter.zip
