Posted 26 October 2020, 12:57 am EST
I was creating a python server with a java client, I manage to send the data from client to the server, however, when it is sent back, the value is not what I expect
Python Server
def handle_client(self, client): # Takes client socket as argument.
“”“Handles a single client connection.”“”
data = [] # get size of data amt = client.recv(self.SIZE) amt = int.from_bytes(amt, byteorder="big", signed=True) client.send("True".encode()) # get type of entre val = client.recv(self.SIZE) val = val.decode() val = val.split(", ") while amt > 0: data.append(val[len(val) - amt]) amt -= 1 if val[0] == "login": # check database u = User() check = u.login(val[1],val[2]) if check: # add once login is confirmed self.clients[val[1]] = data else: b = "false" client.send(b.encode() + '\n')
Java Client
Socket s = new Socket();
s.connect(new InetSocketAddress(voids[1], 7800), 2000);
DataOutputStream dos = new DataOutputStream(this.s.getOutputStream());
DataInputStream ois = new DataInputStream(this.s.getInputStream());
sendPackets(this.al);
b = ois.readByte();
private void sendPackets(HashMap<String, Object> data) throws IOException, InterruptedException {
if (data.containsKey(“Writer”)) {
PrintWriter writer = (PrintWriter) data.get(“Writer”);
data.remove(“Writer”);
writer.write(data.size());
writer.flush();
} else if (data.containsKey(“ObjectStream”)) {
DataOutputStream writer = (DataOutputStream)data.get(“ObjectStream”);
data.remove(“ObjectStream”);
DataInputStream reader = (DataInputStream)data.get(“InputStream”);
data.remove(“InputStream”);
writer.writeInt(data.size());
writer.flush();
String val = String.valueOf(data.get("type")); Byte buf = reader.readByte(); if (data.containsKey("email")) { if (data.containsKey("type")) { val = val + ", "; } val = val + data.get("email"); } if (data.containsKey("username")) { if (data.containsKey("email") || data.containsKey("type")) { val = val + ", "; } val = val + data.get("username"); } if (data.containsKey("password")) { if (data.containsKey("username")) { val = val + ", "; } val = val + data.get("password"); } writer.writeBytes(val); }
If any parts of the codes that are missing that is needed, please tell me
When the string false is sent from Python to Java, the data received is 114. I do not think it is the value I sent from python as when I was debugging it, it receives 114 even when the python server has not sent the String yet
