Posted 15 February 2024, 3:15 am EST
Hi Netsa,
As your project structure is like this:
Window App → Web Service → Reporting Project (Which has ActiveReports references)
Your ‘Entry Assembly Name’ would be the assembly name for your ‘Window App’ and the ‘Calling Assembly Name’ would be the assembly name for your ‘Reporting Project’.
So to generate your ‘.gclicx’ file your command should look like:
C:\ProgramData\GrapeCity\gclm>gclm.exe "742a5cf8-2204-4873-9dc9-ff56d67411bd" -lc ./.gclicx "TestApplication.Reporting.dll"
Assuming ‘TestApplication’ is the assembly name for your Windows Application and ‘Reporting’ is the assembly name for your Reporting Project.
After generating the ‘.gclicx’ file copy it into your class library project and set its ‘Build Action’ property to ‘Embedded Resource’. Now ‘Clean’ and ‘Rebuild’ your class library.
Note: You’ll also need to rebuild your Web Service/Test Application to use the updated Reporting.dll in the projects.
Also, please make sure you delete the ‘licenses.licx’ file for your class library as it is licensed using the ‘.gclicx’ file.
However, if the issue persists please try sharing a stripped-down sample of your application that replicates the issue so we can test the same on our end and further investigate the issue.
Anand
