License issue with Simple Web Designer Sample
Posted by: pierre-yves.ronot on 17 January 2020, 6:22 am EST
    Posted 17 January 2020, 6:22 am EST - Updated 30 September 2022, 3:40 pm EST
    My company is currently evaluating the ActiveReport Professional solution, thus I am working with an trial license.
    For this evaluation, I am following the steps described here: https://www.grapecity.com/activereports/docs/v14/online/how-to-create-simple-web-designer-sample.html
    However, I am stuck at step #14. The page displays a license error:
    According to what is described here, the Licenses.licx should have been automatically generated, but it was not present in the project:
    https://www.grapecity.com/activereports/docs/v14/online/ar-how-licensing-activereports.html
    I have tried creating an empty Licences.licx. It has first generated an error:
    I was able to work around this error using some trick found on StackOverflow (https://stackoverflow.com/a/56593653), but the page still showed the same error (and the App_Licenses.dll was not generated).
    Then I tried filling it with the GrapeCity.ActiveReports.SectionReport, GrapeCity.ActiveReports <…> strings, but it now creates the following errors:
    Please note that I am not familiar with .net, so I might overlook something basic.
    Best regards,
    Pierre-Yves
  • Posted 20 January 2020, 7:40 am EST
    Sorry, we have missed this query somehow. Have you install the ActiveReports through MSI or you are directly using the AR using NPM/NuGet?
    If you are using AR directly from the NPM/NuGet then please install the GC license manager using the following link:
    https://cdn.grapecity.com/license/winclient.zip
    Please remove all your workaround in your sample. Please add the “Licenses.licx” file in properties folder of your project with the following entries:
    GrapeCity.ActiveReports.PageReport, GrapeCity.ActiveReports
    GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport, GrapeCity.ActiveReports.Export.Pdf
    Or you can directly add the attached file in properties folder of your project.
    Hope it helps.
    licenses.zip
