Merging PageReports - header/footers are missing
Posted by: koreilly on 16 November 2022, 11:17 am EST
    Posted 16 November 2022, 11:17 am EST
    I have 2 RDL reports that I am trying to merge using the ReportCombiner but the PageHeader & PageFooters are not rendering.
    [code]
    var combiner = new ReportCombiner();
    var rpt1 = new PageReport();
    var rpt2 = new PageReport();
    rpt1.Load(new FileInfo(_webHostEnvironment.ContentRootPath + @“\Reports\Receipt1.rdlx”));
    rpt1.Report.DataSources[0].ConnectionProperties.ConnectString = _appSettings.Connection;
    rpt2.Load(new FileInfo(_webHostEnvironment.ContentRootPath + @“\Reports\Receipt2.rdlx”));
    rpt2.Report.DataSources[0].ConnectionProperties.ConnectString = _appSettings.Connection;
    combiner.AddReport(rpt1);
    combiner.AddReport(rpt2);
    var filename = “Receipt.pdf”;
    var pdfRe = new GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
    var provider = new GrapeCity.ActiveReports.Rendering.IO.FileStreamProvider(new DirectoryInfo(_webHostEnvironment.ContentRootPath + @"\wwwroot\uploads\temp"), filename);
    combiner.BuildReport().Document.Render(pdfRe, provider);
    [/code].
  • Posted 17 November 2022, 4:55 am EST
    Hi Don,
    Unfortunately, The PageHeader and PageFooter are not rendered when rendering a report using a ReportCombiner or SubReport. This is by design.
    However, we have added a new report type to tackle this issue in the latest ActiveReports 16 version 16.3.1 called ‘RDL-Multi Section Report’ which contains multiple RDL reports each with its own PageHeader/Footer.
    You can add all the reports you want to merge in this along with their respective Header/Footer and they will render as expected.
    Please find attached a sample for the same.
    You may download ActiveReports v16.3.1. from here:
    https://www.grapecity.com/activereportsnet/download
    Anand
    RdlMultiSectionReportApplication1.zip
