Multiple bindings for Tree View parameters?
Posted by: bchun on 13 January 2022, 2:51 pm EST
    Posted 13 January 2022, 2:51 pm EST
    I am trying to add a Tree View filter in my reports in the Web designer and need to bind the selection of values to multiple bindings. (For example, Parent Id to one parameter and Child Id to another parameter). Is this possible?
    If not, am I forced to use two separate parameters that feed off of one another?
  • Posted 18 January 2022, 10:59 am EST - Updated 30 September 2022, 3:18 pm EST
    I thought the TreeView parameter was an available feature in the ActiveReports Web Design. Am I mistaken?
    From the Parameters section, I can see this as an option for parameter types.
  • Posted 21 January 2022, 1:29 am EST
    We apologize for the delay in response, The treeView parameter type in the parameter type panel only provides a hierarchical representation of parameters at the UI level, but they would still be bound to a single parameter at a time, Thus it is not directly possible to bind sections of value to multiple bindings.
    In order to resolve this, you could try using Cascading Parameters to see if that helps.
    For more information on the same, please refer to the below link: https://www.grapecity.com/activereportsnet/docs/v15/online/add-a-cascading-parameter.html
    Dushyant Sharma
