Posted 19 March 2018, 10:24 am EST
Is it possible to set the output file name for a .pdf report using the expression editor? I am using Report Designer to create .rdl reports to be output in .pdf format. I would like to set the name of the output .pdf file using a combination of a text string appended to the contents of a field. For instance, if the text string is “Test Report” and the field contents is “77186”, I would like to set the file name of the .pdf file to be “Test Report 77186.pdf”.
