Page break based on conditions
Posted by: nguyenduyhanlam on 21 November 2019, 5:25 am EST
    Posted 21 November 2019, 5:25 am EST
    Example the data will look like this:
    ColA | ColB | ColC
    1 a a
    2 a b
    28 b a
    29 b b
    N z z
    Binding the datasource in the current section report (i do it in report start function):
    Me.DataSource = MyDataTable
    I have create 3 labels (lblA, lblB, lblC) for 3 columns above in detail section (in design). Each label properties i set the DataField to its column in MyDataTable (ex: lblA will have DataField look like this:
    | DataField | ColA |
    The problem is i don’t know to make the report break to the new page if it:
    1. fully has 45 rows/records in one page
    2. OR ColB has changed to the new letter
      I am using ActiveReport9J.
  • Posted 25 November 2019, 4:32 am EST
    For (1), please refer the following blog to implement the same requirement:
    https://www.grapecity.com/blogs/page-break-after-n-records-section-reports
    For (2), you can set the DataField for grouping, to the value of ColB.
    https://help.grapecity.com/activereports/webhelp/AR9/index.html#AddGrouping.html
    The conditions may change (and not work as expected) if you apply both of these at the same point.
    Note: Support of AR 9 is not provided now as it is out of the maintenance period.
