Page.MeasureText Correct Usage
Posted by: jallen on 13 March 2020, 3:48 pm EST
    Posted 13 March 2020, 3:48 pm EST
    I am hoping to display different text in a section report text box if the text is too long for the text box.
    Is this the correct way to do it?
    Public Class SectionReport1
        Private Counter As Integer = 0
        Dim Text1 As String = "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Maecenas aliquet hendrerit tortor"
        Private Sub SectionReport1_DataInitialize(sender As Object, e As EventArgs) Handles Me.DataInitialize
            Fields.Add("Test")
        End Sub
        Private Sub Detail_Format(sender As Object, e As EventArgs) Handles Detail.Format
            If CurrentPage.MeasureText(Text1).Width > TextBox1.Width Then
                TextBox1.Text = "TOO LONG"
            End If
        End Sub
        Private Sub SectionReport1_FetchData(sender As Object, eArgs As FetchEventArgs) Handles Me.FetchData
            Counter += 1
            If Counter = 10 Then
                eArgs.EOF = True
                Return
            End If
            Fields("Test").Value = Text1
            eArgs.EOF = False
        End Sub
    End Class
    The code above is not accurate enough, since the ‘TOO LONG’ message does not display even though the text is truncated.
    John
  • Posted 17 March 2020, 6:34 am EST
    Could you please try with the following line of code:
            If CurrentPage.MeasureText(Text1, TextBox1.Font).Width > TextBox1.Width Then
            End If
        End Sub
        Private Sub SectionReport1_DataInitialize(sender As Object, e As EventArgs) Handles MyBase.DataInitialize
            Fields.Add("Test")
        End Sub
        Private Sub SectionReport1_FetchData(sender As Object, eArgs As FetchEventArgs) Handles MyBase.FetchData
            Counter += 1
                eArgs.EOF = True
                Return
            End If
            eArgs.EOF = False
        End Sub
    If the issue is still reproducible, then could you please modify the attached sample so that I can reproduce the issue at my end.
    SectionReportApplication53.zip
  • Posted 17 March 2020, 8:58 am EST
    That is good, thanks!
    John
