Pass windows Printer Settings to Active Report document
Posted by: mdynna on 10 December 2024, 3:40 pm EST
    Posted 10 December 2024, 3:40 pm EST
    When viewing a report in the Preview window, the Printer Settings dialog can be displayed to modify things such as duplexing or tray settings.
    We want to give the user the option of setting the Printer Settings prior to the report running, without having to show the report in the previewer. If we display the standard .NET Printer Settings dialog box to fill the PrinterSettings object, how can we pass that to the Active Report after the report has run so that the settings are used when the report is sent to the printer?
  • Posted 11 December 2024, 4:28 am EST
    Hi Mark,
    To enable users to configure Printer Settings before running the report without displaying it in the Viewer, you can utilize the
    System.Windows.Forms.PrintDialog
    class to collect the desired settings. After the user selects their printer settings, these settings can be applied directly to the
    rpt.Document.Printer.PrinterSettings
    before initiating the print job. To facilitate this, we’ve created a custom extension, PrinterSettingExtension, that transfers the printer settings from the .NET PrinterSettings object to the ActiveReports PrinterSettings. Once the settings are applied, the report is printed using the specified configuration.
    Please refer to the attached sample where we’ve implemented an extension to copy settings between PrinterSettings objects. You can integrate a similar approach into your project. If you encounter any challenges with specific events or methods during implementation, kindly share the details with us, and we’ll assist you in providing a tailored solution.
    We hope this helps!
    Attachment: PrinterSettings.zip
  • Posted 11 December 2024, 3:08 pm EST
    Thanks. Are you able to upload the sample app with a solution compatible with Visual Studio 2019?
  • Posted 12 December 2024, 2:34 am EST
    Hi Mark,
    Sure, please refer to the attached sample compatible with Visual Studio 2019.
    Attachment: VS19_Info.zipPrinterSettings_VS19.zip
  • Posted 8 January 2025, 3:56 pm EST - Updated 8 January 2025, 4:01 pm EST
    I am working on the same problem.
    In the attached screenshot there are printer settings where I cannot find corresponding properties in the IPrinterSettings interface. The user will not be able to change these settings for printing the way they can when launching the print dialog from the report viewer preview?
  • Posted 9 January 2025, 3:30 am EST
    Hi John,
    We found the three properties to be existing in the
    System.Printing.PrintTicket
    class. However, we couldn’t find any corresponding properties for them in GrapeCity.ActiveReports.Printing.IPrinterSettings.
    We have escalated this to our development team for their insights on the sane and will get back to you as soon as we have any updates [Internal tracking ID: AR-34907].
    Thanks for your patience!
  • Posted 25 April 2025, 3:08 pm EST
    Your sample project for the code in the PrinterSettingExtension class doesn’t work for the Copy of the PrintRange and Duplex options in Active Reports v18.2.2. When debugging, I can see it change inside the Copy extension for these two properties. However, once it exits the copy and goes back to the main Copy extension method, the values don’t actually change. I assume these properties aren’ t being passing by reference for some reason. So this doesn’t bite anyone else with it not working correctly, set these two properties directly.
            public static void Copy(this GrapeCity.ActiveReports.Printing.IPrinterSettings reportPrinterSettings,
            System.Drawing.Printing.PrinterSettings userPrinterSettings)
                switch (userPrinterSettings.PrintRange)
                    case System.Drawing.Printing.PrintRange.AllPages:
                        reportPrinterSettings.PrintRange = GrapeCity.ActiveReports.Printing.PrintRange.AllPages;
                        break;
                    case System.Drawing.Printing.PrintRange.Selection:
                        reportPrinterSettings.PrintRange = GrapeCity.ActiveReports.Printing.PrintRange.Selection;
                        break;
                    case System.Drawing.Printing.PrintRange.CurrentPage:
                        reportPrinterSettings.PrintRange = GrapeCity.ActiveReports.Printing.PrintRange.CurrentPage;
                        break;
                    case System.Drawing.Printing.PrintRange.SomePages:
                        reportPrinterSettings.PrintRange = GrapeCity.ActiveReports.Printing.PrintRange.SomePages;
                        break;
                    default:
                        break;
                switch (userPrinterSettings.Duplex)
                    case System.Drawing.Printing.Duplex.Default:
                        reportPrinterSettings.Duplex = GrapeCity.ActiveReports.Printing.Duplex.Default;
                        break;
                    case System.Drawing.Printing.Duplex.Simplex:
                        reportPrinterSettings.Duplex = GrapeCity.ActiveReports.Printing.Duplex.Simplex;
                        break;
                    case System.Drawing.Printing.Duplex.Horizontal:
                        reportPrinterSettings.Duplex = GrapeCity.ActiveReports.Printing.Duplex.Horizontal;
                        break;
                    case System.Drawing.Printing.Duplex.Vertical:
                        reportPrinterSettings.Duplex = GrapeCity.ActiveReports.Printing.Duplex.Vertical;
                        break;
                    default:
                        break;
  • Posted 1 May 2025, 2:01 am EST
    Hi Dennis,
    Thank you for pointing this out to us. You may refer to the attached sample for the fix.
  • Posted 13 May 2025, 11:50 am EST
    I am not sure that the latest solution provided fixes the issue of not being able to copy advanced printer settings as indicated in my post of 8 January 2025.
    However, this is no longer a priority for us (I work with mdynna), as, given the challenges involved, we have decided for now not to attempt to let the user adjust all of these printer settings prior to running the report.
    Thank you for your time,
    John
