Passing and retrieving parameters through ActiveReports web designer
Posted by: bchun on 11 January 2022, 5:56 pm EST
    Posted 11 January 2022, 5:56 pm EST
    I am fairly new to ActiveReports report development. I am wondering if there is a way to pass and retrieve parameters to reports on the Web Designer interface as our web application would like to pass some parameters to reports. I’ve looked through the forums, but there are no definitive method to do this. Is there any way to do this?
    Thanks!
  • Posted 12 January 2022, 6:11 am EST
    Hello ,
    if it is enough to have a control under parameters in the report templates(the end user will use these templates to create the report), then you could use the templates service and controller like in the following sample:
    https://github.com/activereports/WebSamples15/tree/main/WebDesignerSamples/WebDesigner_CustomStore
    in case of access to the parameters of any loading report, you could use the custom resource storage from the same sample.
    Sergey Romanov.
