Posted 14 June 2021, 9:39 pm EST - Updated 30 September 2022, 3:24 pm EST
Passing parameter from Angular to file rdlx
Posted by: duonghb53 on 14 June 2021, 9:39 pm EST
Posted 15 June 2021, 3:16 am EST
Can you please check with the attached sample. If issue is not reproducible with my attached sample, then, please modify it and share with us so that I can replicate the issue at my end.
Mohit -
Posted 15 June 2021, 3:20 am EST
Dear Mohitg
Where’s yours sample code. I don’t see it. -
Posted 15 June 2021, 3:25 am EST
Posted 15 June 2021, 3:49 am EST - Updated 30 September 2022, 3:19 pm EST
Dear Mohitg
Thank a lot.
I will try sample code and response. -
Posted 15 June 2021, 10:28 pm EST
Dear Mohitg
I seem to have understood my problem.
I think when use:reportParameters: [{ name: 'fiscal_year', values: ['2021'] }, { name: 'organization_cd', values: ['0000'] }],
it will create parameter in file rdlx but I have to create parameter in file rdlx first and then can passing data with parameterName to file rdlx.
Is this right?
Thank you. -
Posted 16 June 2021, 12:08 am EST
Yes, it will not create the parameter in the report automatically. You need to create the parameter in the rdlx file first then you can pass the value to the parameter through JSViewer.Thanks,
Mohit -
Posted 16 June 2021, 12:24 am EST
Dear Mohitg
Thank you for your support.
