Print existing file using ActiveReport 2010
Posted by: albinibraimi on 11 July 2023, 11:07 am EST
    Posted 11 July 2023, 11:07 am EST - Updated 12 July 2023, 5:14 am EST
    Hello, I’m working on old project that use ActiveReports 6 from 2010.
    The requirement is to print existing PDF file that will be provided with a byte stream or byte array using ActiveReprots. Is this possible?
  • Posted 12 July 2023, 7:31 am EST
    Hi Albin,
    Unfortunately, it is not possible to load and print PDF files using ActiveReports. However, we do have a different product GcPDF using which you can load your PDF file, customize/modify it as per your requirements and print it.
    You may refer to the following references to learn more about loading and printing your PDF files using GcPDF Load PDF Print PDF.
    You may try GcPDF free for the first 30 days by downloading the same from here Download GcPDF.
    For any queries regarding GcPDF you may reach out to our GcPDF support team at Forums.
    Anand
