Posted 5 September 2024, 4:37 am EST
- Updated 5 September 2024, 4:42 am EST
Hi Mark,
ActiveReports does provide Viewers that support technologies like Blazor, ASP.NET Core, ASP.NET MVC, Angular, React, HTML5/JS, WPF, and WinForms. You may refer to the attached link to know more about them: Report Readers
Also, please note that if you have a parameter that can’t be null or does not have a default value specified, then it will require the user to enter the parameter value before rendering the report. To overcome that, you can make the parameter accept null values by checking the Allow null values option of the parameter (see NullValues.png). For setting default value of the parameter, you may refer to the attached documentation page: Hidden Parameter. Here you can skip the option of making the parameter Hidden so that you can also change its value via the Viewer as well.
We hope this helps!
