RPX to RDL conversion loses XPath DataFields
Posted by: peter.smith on 22 January 2020, 8:51 am EST
  • Posted 22 January 2020, 8:51 am EST
    I have several ActiveReports 6 RPX reports that use and XmlDataSource and XPath fields.
    Here is an example :
    <Section Type="GroupHeader" Name="Entête_Empr" Visible="0" Height="144" DataField="../Destinataire/IDEMPR_RESP" BackColor="16777215" />
    The conversion process gives the following result :
    <GroupExpression>=../Fields!Destinataire.Value/Fields!IDEMPR_RESP.Value</GroupExpression>
    I suppose that ActiveReports tried to create a DataSet based on the XmlDataSource. But it seems that the XPath expressions are not handled the right way.
    The generated RDL DataSource looks like this :
    	<DataSets>
    		<DataSet Name="DataSet1">
    			<Fields>
    				<Field Name="Destinataire">
    					<DataField>Destinataire</DataField>
    				</Field>
    				<Field Name="CP">
    					<DataField>CP</DataField>
    				</Field>
    Editing the generated RDL report to set XPath manually back actually works. And the code then looks like this :
    			<Fields>
    				<Field Name="IDEMPR_RESP">
    					<DataField>../Destinataire/IDEMPR_RESP</DataField>
    				</Field>
    <GroupExpression>=Fields!IDEMPR_RESP.Value</GroupExpression>
    Could you confirm this behaviour ?
    Thanks for your attention
  • Posted 24 January 2020, 2:58 am EST
    I am able to reproduce the issue at our end. I will escalate the issue to our development team(278219) and inform you once I get any reply from them.
