Posted 12 February 2023, 9:38 pm EST - Updated 12 February 2023, 9:43 pm EST
Run time error on ActiveReport PageReport
Posted by: ken.kw.tsui on 12 February 2023, 9:38 pm EST
Posted 13 February 2023, 5:54 am EST
Hi Ken,
It seems like your application is not correctly licensed:
If your project is a class library project, you’ll need to create a ‘.gclicx’ license file and embed it into your project.
You may learn more about the same here - Licensing Compiled Code: https://www.grapecity.com/activereportsnet/docs/latest/online/licensing-compiled-code.html (This is for ActiveReports 17, please refer to ‘Licensing Compiled Code’ in the documentation for your version of ActiveReports as the ‘Product ID’ in the command varies for each version.)If your project is not a class library and directly uses ActiveReports references please make sure your ‘license.licx’ file has all the valid string entries for your project. You may refer here for all the license strings that you may need: https://www.grapecity.com/activereportsnet/docs/versions/v16/online/licensing-a-project.html#:~:text=The%20below%20table%20lists%20all the%20license%20strings%20that%20you%20may%20need%3A
If the issue persists please tell us more about your project’s structure, and share a stripped-down sample if possible so we can look further into the issue.
Anand
