Setting a Picture using ReportSection.Fields[].Value has no effect
Posted by: cristian.udrea on 6 December 2023, 7:14 am EST
    Posted 6 December 2023, 7:14 am EST
    The following code used to work under ActiveReports 6, however under ActiveReports 17 the corresponding Picture control from the Report appears empty.
    Our application code overrides SectionReport.FetchData like this:
    report.FetchData += new FetchEventHandler(this.CutFlange_FetchData);
    Then, in the method CutFlange_FetchData, we try to set the picture like this:
    Bitmap flangeBitmap = BitmapsCache.getBitmap(flageCutName);
    Field cutFlangePic = report.Fields["CutFlangePicture"];
    cutFlangePic.Value = flangeBitmap;
    flangeBitmap is a valid bitmap and cutFlangePic also appears to be valid.
    Is this way of setting a picture still valid ?
    If not how should I proceed ?
  • Posted 6 December 2023, 9:03 pm EST
    Found the solution to my problem:
    A Field that is bound to a Picture control won’t take a System.Drawing.Bitmap as Value.
    However it will take a GrapeCity.ActiveReports.Document.Drawing.Image as Value and display it properly.
  • Posted 6 December 2023, 11:53 pm EST
    Hi Cristian,
    I am glad to know your issue is resolved!
