Posted 10 May 2018, 9:20 am EST
Hi There,
I have made it much further along so thanks for your help so far. I am trying to set a proxy as part of my command to activate the license. Something like set http_proxy=http://someproxy.paychex.com:80. This enables me to use curl to hit the activation site, but when I try to activate the license via command line I get and error.
There was a problem connecting to the GrapeCity Activation Service. Please check the internet settings and try again.
If I set the proxy via IE then it works via command line. But this is not very usueful for automation. Can you let me know if there is a proxy environment variable that needs to be set to allow the license manager exe to access the internet. Is it possible it is using some other protocol other than http? Can you share how it access the activation site?
Here is the command I use in the command prompt:
GrapeCity.LicenseManager.exe /Activate /Product:"ActiveReports 9" /ProductKey:someproductkey /UserName:bernie /CompanyName:Paychex /Email:bbonn@paychex.com
Thanks for any help!!
Bernie
