SQLite connection
Posted by: robert on 25 January 2018, 5:15 pm EST
    Posted 25 January 2018, 5:15 pm EST
    Using VS2017 ARvs11
    if I use access as the database, this works
    "Dim dbPath As String = frmMain.lblPath.Text ’ “C:\Users\Robert\Documents\Visual Studio 2010\Projects\etc…” ’
        '    Dim connString As String = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source= " + dbPath + ";Jet OLEDB:Database Password=********"
        '    conn = New OleDbConnection(connString)"
    if I use SQLite this does not work
    Dim connString As New SQLiteConnection(connectonString)
            Dim readBankAcctData As String = "SELECT BankAcctID, BankName, TransitNo, InstNo, AcctNo, AcctDefault, AcctType, AcctDteOpened, AcctDebitNo, AcctName, AcctDteClosed FROM tblBankAccts"
            Dim cmd As New SQLiteCommand(readBankAcctData, connString)
            connString.Open()
            Dim reader As SQLiteDataReader = cmd.ExecuteReader()
            Me.DataSource = reader
    How do I connect my report to the SQLite database?
    Robert
    robert@rjenterprize.com
  • Posted 29 January 2018, 12:37 am EST
    Could you please confirm are you using same connection string for SQLite as for OleDB("Provider=Microsoft.Jet.OLEDB.4.0;Data Source= " + dbPath + “;Jet OLEDB:Database Password=********”). If so, you need to change the connection string for SQLite because both using the different provider.
    For example:
    Dim connString As String = “user id=XX;data source=XXXXXXX;initial catalog=XXXXXX;password=XXXXXX;”
    If our assumption is incorrect, please share the connection string that you are using with SQLite and error message which is displayed on connecting SQLite.
  • Posted 30 January 2018, 7:01 pm EST
    the problem is not the connection string
    if i do a
            If reader.HasRows() Then
              While reader.Read
                   lblBankNameID.Text = reader("BankAcctID")
                   txtBank.Text = reader("BankName")
               End While
            End If
    So the issue is the Active Report reader
    Using vs: 11
    Any ideas???
  • Posted 31 January 2018, 4:22 am EST
    I am unable to reproduce the issue on my end. Please refer the attached sample.
    Could you please attach your report file for me to run and reproduce the issue. Can you please specify the exact version of AR that you’re facing the issue with?
    prj_sqlLiteDatabase.zip
