Subreport in Group Footer
Posted by: traci.leonard on 19 February 2019, 12:41 pm EST
    Posted 19 February 2019, 12:41 pm EST
    I have a report with a Subreport. Everything works fine when I put the subreport in a group header, but when I put it into a group footer (where we need it to go) the sub report shows the data from the next record. How can I fix this so it is grabbing the right data?
  • Posted 22 February 2019, 3:35 am EST
    In case you are taking the parameters for subreport directly from the fields collection of the main report and it is not synchronized (i.e., if you use the fields collection from of Detail Format event handler), then it is recommended to add a databound TextBox control (hidden) to the group footer section and use its Text property value in GroupFooter format as a parameter.
    In case this does not help, kindly share your sample report with dummy data so that I can observe the issue at my end and assist you further.
    Thanks and Regards,
