Posted 3 September 2019, 7:40 am EST
I have a array of strings.
I want to perform an substring search in that array.
array is ```
Join(Parameters!ChartTable.Value, “,”)
Example :
IIF( condition, True, False)
Forums Home / ActiveReports / General Discussion
Posted by: ashna.asif on 3 September 2019, 7:40 am EST
array is ```
Example :
Posted 3 September 2019, 8:02 am EST
Hello Ashna,
Please use the following expression:
=IIF((Join( [@ReportParameter1] , “,”).Contains(“test2”),True,False)
Also, please refer to the attached report.
rpt_Containms.zip
Hello Ashna,
rpt_Containms.zip
Posted 3 September 2019, 8:25 am EST - Updated 30 September 2022, 3:05 pm EST
Thanks for the solution.
Where can I find these functions. Can you provide me some documentation to refer.
Posted 3 September 2019, 8:29 am EST
Hello Ashna,
These are the common Vb function which can be used in the AR Expression. However, you can refer to the following documentation links:
https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#Expressions.html
https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#CommonValues.html
https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#CommonFunctions.html
https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#LookupSetFunctioninDataRegions.html
Hope it helps.
