Posted 23 January 2025, 6:18 pm EST - Updated 23 January 2025, 6:20 pm EST
I have 10 different SQL queries in the DataSource
They all work perfectly in my SQL Management Studio and working in the 17.1 version, but after I upgrade the version to 17.3, I got the following errors. There is no way to debug. Please help me find the reasons. Also, why this Report Designer just not able to return a useful error message? At least tell me which dataset, btw all of them past the Dataset validation
Exception details:
GrapeCity.ActiveReports.ReportException: An unexpected error occurred. Additional information: 'Incorrect syntax near ')'.
Incorrect syntax near ')'.' ---> System.Data.SqlClient.SqlException: Incorrect syntax near ')'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader()
at GrapeCity.ActiveReports.Rendering.DataProcessing.RecordsAdapter.<GetEnumerator>d__8.MoveNext()
at GrapeCity.Enterprise.Data.DataEngine.Extensions.MemoizeEnumerableExtensions.MemoizedReadOnlyList`1.CacheItem()
at GrapeCity.Enterprise.Data.DataEngine.Extensions.MemoizeEnumerableExtensions.MemoizedReadOnlyList`1.<GetLiveEnumerator>d__8.MoveNext()
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at System.Linq.Lookup`2.Create[TSource](IEnumerable`1 source, Func`2 keySelector, Func`2 elementSelector, IEqualityComparer`1 comparer)
at System.Linq.GroupedEnumerable`3.GetEnumerator()
at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source)
at GrapeCity.Enterprise.Data.DataEngine.DataProcessing.DataProcessor.<>c__DisplayClass10_1.<MakeListFn>b__2()
at GrapeCity.Enterprise.Data.DataEngine.DataTree`1.List.get_Groups()
at Gcef.Data.DataEngine.I...()
at GrapeCity.ActiveReports.Core.Rendering.I..get_Contents()
at GrapeCity.ActiveReports.Core.Rendering.I...GatherChildren(IFixedPage a)
at GrapeCity.ActiveReports.Core.Rendering.I..Children( a)
at GrapeCity.ActiveReports.Core.Rendering.I...MoveNext()
at GrapeCity.Enterprise.Data.Expressions.Tools.EnumerableExtensions.<Flatten>d__0`1.MoveNext()
at GrapeCity.ActiveReports.Core.Rendering.I..(IEnumerable`1 )
at GrapeCity.ActiveReports.Core.Rendering.I..( , IReadOnlyList`1 )
at GrapeCity.ActiveReports.Core.Rendering.I...()
at GrapeCity.ActiveReports.Rendering.DocumentMapNode.<>c__DisplayClass3_0.<.ctor>b__0()
at System.Lazy`1.CreateValue()
at System.Lazy`1.LazyInitValue()
at System.Lazy`1.get_Value()
at GrapeCity.ActiveReports.Core.Rendering.I..(IMetadataDictionary , DocumentMapNode , ILayoutArea )
at GrapeCity.ActiveReports.Core.Rendering.I..Build(IReport a, IMetadataDictionary b)
at GrapeCity.ActiveReports.Core.Rendering.I..( , Point`1 , , Boolean , Boolean , Boolean , Int32 , Boolean )
at GrapeCity.ActiveReports.Core.Rendering.I..BuildPages( a, Int32 b)
at GrapeCity.ActiveReports.Core.Rendering.I...get_Pages()
at GrapeCity.ActiveReports.Viewer.Common.Rdlx.GraphicsRenderingExtension.GetLayoutPages(CancellationToken cancel, Boolean awaitFullLayout)
at GrapeCity.ActiveReports.Viewer.Common.Rdlx.GraphicsRenderingExtension.DrawPages(IFontsFactory fonts, CancellationToken cancellationToken, Boolean awaitFullLayout)
at GrapeCity.ActiveReports.Viewer.Common.Rdlx.GraphicsRenderingExtension.Render(IReport report, CancellationToken cancel)
at GrapeCity.ActiveReports.Viewer.Common.Rdlx.GraphicsRenderingExtension.Render(IReport report, StreamProvider streams, NameValueCollection settings, CancellationToken cancel)
at GrapeCity.ActiveReports.Document.PageDocument.Render(IRenderingExtension renderingExtension, StreamProvider streams, NameValueCollection settings, Boolean forceDataRefresh, Boolean forceParameterDataRefresh, CancellationToken token, IProgress`1 progress)
--- End of inner exception stack trace ---
at GrapeCity.ActiveReports.Viewer.Common.Internal.RdlReport.<>c__DisplayClass23_0.<LoadImpl>b__8()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
