This application will be terminated because it was built without a license for
Posted by: mhabes on 4 February 2021, 4:28 pm EST
    Posted 4 February 2021, 4:28 pm EST
    I’m getting the following error and have tried everything. My AR15 license is active on my development machine. I have a class library that is packaged into a NuGet package and consumed by a web application.
    Both the class library and the web application have licenses.licx files with the following:
    GrapeCity.ActiveReports.SectionReport, GrapeCity.ActiveReports, Version=15.0.3.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
    GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport, GrapeCity.ActiveReports.Export.Pdf, Version=15.0.3.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
    Here is the error:
    System.ComponentModel.LicenseException: This application will be terminated because it was built without a license for SectionReport. at GrapeCity.ActiveReports.SectionReport.Run(Boolean syncDocument) at BFGSupply.BFGApi.Report.ReportHelper.GetReport(ReportDefinition reportDefinition, DataTable data) at BFGSupply.BFGApi.Report.ReportHelper.GetReport(ReportDefinition reportDefinition) at BFGSupply.BFGApi.Service.Reports.EntityFrameworkReportService.RunReport(ReportDefinition report)
    Visual studio 2019, .Net 4.8, debugging locally or deployed to web server is the same result.
    Any help would be greatly appreciated. Upgrade from AR10. Reports all look good. Can run the report directly from the class library but not the web app.
  • Posted 5 February 2021, 12:26 am EST
    Your query has been replied here:
    https://supportone.componentone.com/casedetail/472537
    Please reply to above support one query to avoid confusion.
  • Posted 5 February 2021, 6:14 am EST - Updated 30 September 2022, 3:18 pm EST
    Hi, I have the same issue Upgrading from AR13 and Windows Form Viewer
    Thank you
  • Posted 7 February 2021, 9:46 am EST
    Could you please make sure that you have correct entry in the Licenses.licx file.
  • Posted 8 February 2021, 5:35 am EST
    That’s the licenses.licx content:
    GrapeCity.ActiveReports.Viewer.Win.Viewer, GrapeCity.ActiveReports.Viewer.Win, Version=15.0.3.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
  • Posted 9 February 2021, 5:43 am EST
    https://supportone.componentone.com/casedetail/472629
  • Posted 14 June 2021, 5:05 pm EST
    I am encountering the same issue, upgrading from AR6 to AR15.1. My license file has the following entries:
    GrapeCity.ActiveReports.SectionReport, GrapeCity.ActiveReports, Version=15.1.0.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
    GrapeCity.ActiveReports.Viewer.Win.Viewer, GrapeCity.ActiveReports.Viewer.Win, Version=15.1.0.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
    GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport, GrapeCity.ActiveReports.Export.Pdf, Version=15.1.0.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
    GrapeCity.ActiveReports.PageReport, GrapeCity.ActiveReports, Version=15.1.0.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff
  • Posted 15 June 2021, 2:06 am EST
    Could you please provide me the sample so that I can replicate the issue at my end. Also, you can try following thing:
    Try to run the sample at the following location and see it gives the same issue:
    https://github.com/activereports/Samples15/tree/main/Desktop/WinViewer
    Try to create a new application using the AR project template and see it gives the same issue.
    Also, you can try after deleting the bin/obj folder
    If both run correctly, I need your sample so that I can reproduce the issue at my end.
  • Posted 15 June 2021, 1:34 pm EST
    Mohit,
    I successfully ran the sample and several new test projects using the templates. I have deleted the bin/obj folders in the relevant projects within my solution, but still get the same error. My solution/projects well exceeded the max size limits for me to attach here. Please advise.
    Thank you,
    Paul
  • Posted 16 June 2021, 12:18 am EST
    Can you tell me the project structure of the solution? If you are using AR assemblies in the class library and use the class library in another project then you need to refer to the following link:
    https://www.grapecity.com/activereportsnet/docs/v15/online/licensing-compiled-code.html
  • Posted 13 July 2021, 2:58 pm EST
    Error while running report (from ReSharperTestRunner32) : This application will be terminated because it was built without a license for SectionReport. at GrapeCity.ActiveReports.SectionReport.Run(Boolean syncDocument)
    at GrapeCity.ActiveReports.SectionReport.Run() …
    Getting the above exception.
    I’ve created a ReSharperTestRunner32.gclicx license from the cli below and it is an embedded resource in my FCS.Reporting.Requests.ProcessorRequests project.
    C:\ProgramData\GrapeCity\gclm\gclm.exe “e88c1aa3-2781-44bb-b639-765c9ef6d15c” -lc C:\dev\ReSharperTestRunner32.gclicx “ReSharperTestRunner32.FCS.Reporting.Requests.ProcessorRequests.dll”
    Please advise?
  • Posted 14 July 2021, 4:06 am EST
    Are you using AR15 or AR14?
    If AR14, please try with the following command:
    C:\ProgramData\GrapeCity\gclm\gclm.exe “de456e2c-d2e3-4246-94e8-9648bbd6fbf0” -lc ..gclicx “ReSharperTestRunner32.FCS.Reporting.Requests.ProcessorRequests.dll”
    IF AR15, then please try with the following command:
    C:\ProgramData\GrapeCity\gclm\gclm.exe “e88c1aa3-2781-44bb-b639-765c9ef6d15c” -lc ..gclicx “ReSharperTestRunner32.FCS.Reporting.Requests.ProcessorRequests.dll”
    Hope it helps.
    Mohti
  • Posted 14 July 2021, 1:54 pm EST
    Using v15 and my cli call is what you suggest - and it doesn’t resolve the issue.
  • Posted 15 July 2021, 1:45 pm EST
    Could you please tell the all license steps you followed and your deploy steps so that I can narrow down the issue.
  • Posted 8 January 2022, 4:02 am EST
    I need a real sample which the lisencing for a activerports 15 is actually done. would you please send a sample .
    thanks
    Shahin
