Web Designer - Parameter asks for input, but 'select all' default value set
Posted by: bchun on 18 January 2022, 12:14 pm EST
    Posted 18 January 2022, 12:14 pm EST - Updated 30 September 2022, 3:17 pm EST
    In my report, I’ve set several parameters to have a ‘select all’ value of -1 and a default value of -1, the same as the ‘select all’ value.
    However, when I preview the report, the parameters still require me to select a value (see screenshot below) even though the default value is set to the ‘select all’ value. Is this there something I am missing here?
  • Posted 24 January 2022, 5:52 am EST
    We are not able to replicate the issue at our end, please try updating your project to the latest version of Active Reports and then retry the same.
    If the issue persists, kindly provide a sample report file depicting the issue or make changes in the below sample, so that we may debug it and reply accordingly.
    Please find the sample and report file used to test out the above issue attached below.
    Dushyant Sharma
    Sample Project: WebDesigner_MVC_Core.zip
    Report File:ReportParameter_SelectAll.zip
  • Posted 24 January 2022, 6:01 pm EST
    Hi Dushyant.
    The rdlx files I have created are in JSON format, whereas the sample you have provided is in xml and does not seem to open properly in Web Designer. Would you have a sample that is in JSON? Am I running Web Designer in a different ActiveReports.NET version that does not support XML?
  • Posted 27 January 2022, 2:15 pm EST
    Could you inform us whether you are using ActiveReports or ActiveReportsJS? Furthermore, please specify the build version of the same.
    Dushyant Sharma
  • Posted 27 January 2022, 3:47 pm EST
    Hi Dushyant,
    From what I’ve been told, we are using ActiveReports on build 15.2.
    Thanks!
  • Posted 28 January 2022, 10:54 am EST
    Hi Dushyant,
    I believe this now has something to do with reports saved in JSON format for the Web Designer in ActiveReports. We recently moved to store our reports in XML and this issue does not appear to be happening any longer.
  • Posted 2 February 2022, 8:10 am EST
    I am glad to know your issue has been resolved! Do let us know if you need any help in the future.
