WebViewer problem in AR15
Posted by: librasoft on 19 April 2023, 2:09 pm EST
    Posted 19 April 2023, 2:09 pm EST
    When i working in VS2019 IDE the project are runs fine and shows section report in webviewer, but after deployment to remorte server the error occur “Report not found: Report Instance Error-63716305”.
    code language is VB.Net
    global.asax.vb
    Imports System.Web.Http
    Imports System.IO
    Imports GrapeCity.ActiveReports.Web
    Public Class Global_asax
    Inherits System.Web.HttpApplication
    Protected Sub Application_Start(ByVal sender As Object, ByVal e As EventArgs)
    Me.UseReporting(Sub(settings)
    settings.UseFileStore(New DirectoryInfo(Server.MapPath(“~”)))
    settings.UseCompression = True
    settings.UseCustomStore(AddressOf GetReport)
    End Sub)
    End Sub
    Public Function GetReport(ByVal Optional reportName As String = “SectionReport”) As Object
    Dim rpt As SectionReport1 = New SectionReport1()
    Return rpt
    End Function
    End Class
    default.asax.vb
    Public Class _Default
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
    Dim rpt As New SectionReport1()
    rpt.Restart()
    WebViewer1.Report = rpt
    rpt.Run()
    End Sub
    End Class
    default.axpx
    <%@ Page Language=“vb” AutoEventWireup=“false” CodeBehind=“Default.aspx.vb” Inherits=“WebApplication2._Default” %>
    <%@ Register assembly=“GrapeCity.ActiveReports.Web” namespace=“GrapeCity.ActiveReports.Web” tagprefix=“ActiveReportsWeb” %>
    sectionReort1.vb
  • Posted 21 April 2023, 1:35 am EST
    Hi Imran,
    We tried to replicate the issue by creating a new ‘SectionReport1.vb’ and using your exact code in our sample. And deploying the same in our case to Azure, however, the issue does not seem to replicate on our end.
    We have attached a sample for your reference you may refer/modify the same as per your requirements.
    However, if the issue persists please try sharing a sample that replicates the issue, also tell us more about the server you are deploying your project to so we could test the same on our end and further investigate the issue.
    Anand
    WebViewer_ASP.NET_VB.NET.zip
