Width of SubReport is not completely fitting in Table Control for RDLX
Posted by: kunal on 3 October 2018, 6:22 am EST
    Posted 3 October 2018, 6:22 am EST
    I have a subreport which width is (Size= 24.90055cm, 2.55cm), and In my main report there is a table which size is also 24.90055cm, 2.55cm same with single column, I put that sub report in that table (main report table).
    Here problem is that my subreport result is showing less width then the actual table size. Can any one help me on this issue ?
  • Posted 3 October 2018, 6:25 am EST
  • Posted 3 October 2018, 6:56 am EST
    Please try after setting the margin of Subreport to 0cm.
    Hope it helps.
  • Posted 3 October 2018, 7:07 am EST
    No, even setting margin to 0cm, it is not fitting into the main table width. I have attached my report screenshot, In the right hand side highlighted with pencil, that space i need to use and below highlighted is my sub report.
  • Posted 3 October 2018, 7:08 am EST
  • Posted 3 October 2018, 8:40 am EST
    Any Update please ?
  • Posted 4 October 2018, 1:57 am EST
    I am unable to run your report at my end due to the database issue. However, issue is not reproducible with the attached report. Please refer to the attached files. Also, could you please check after setting the BorderStyle of Table of SubReport to Solid.
    Main.zip
  • Posted 4 October 2018, 4:47 am EST
    Thanks, it works.
