Abnormal application of the Label text template
Posted by: hyeweon.kang on 5 September 2021, 9:35 pm EST
    Posted 5 September 2021, 9:35 pm EST - Updated 3 October 2022, 8:10 am EST
    Hello
    While I creating the bar graph, I found a bug in Color Field Value that was template of label text.
    We wanted to see the % value at the red box location below. However, sometimes the % text is good, and bugs are often found with the date and time.
    I want to ask why it looks like this.
    I attached the Json file, so please check it.
  • Posted 5 September 2021, 9:37 pm EST
    AGA_REPORT.zip
    Here is the json file.
  • Posted 6 September 2021, 6:39 am EST
    Hello, Hyeweon,
    Unfortunately, the report you attached can’t be run on our system because the data are not available. could you provide a version of the report that contains only the chart that provides the unexpected output and some embedded data so that we can run this report on our end?
