Angular sample & designer compatibility
Posted by: ian on 10 May 2023, 10:34 am EST
    Posted 10 May 2023, 10:34 am EST
    I have downloaded the evaluation version of the windows report designer and have pulled the sample angular code from the samples git repo.
    It seems that the rdlx-json files generated by the designer are not compatible with the sample angular project (I get an error stating ‘Cannot read properties of undefined (reading ‘trim’)’). This happens if I simply load one of the sample files into the designer and save it again.
    Do I need to update/downdate dependency version(s) in the sample app (its currently set to @grapecity/activereports-angular ^3.2)? If so what version(s) are compatible?
  • Posted 11 May 2023, 4:21 am EST
    Hi Ian,
    You can check the designer version by opening the designer then go to Files and click on About. I suspect you might be using version 4.0.1 for the designer. I would suggest you to upgrade the ActiveReports packages to v4.0.1 or v4.0.2 in the sample and then use the
    npm install --force
    command to install the packages in the sample.
    If the issue persists then share the sample project you are using and a sample report file so we can reproduce this issue at our end and get back to you accordingly.
  • Posted 11 May 2023, 5:24 am EST
    The Angular sample on Github has been updated to v4, and it can now handle the report templates that were created by using the standalone designer application v4.
  • Posted 11 May 2023, 6:03 am EST
    Great thanks I’ll try it out
