AR JS Viewer with Vue.js problem
Posted by: goldli on 19 March 2020, 5:17 am EST
    Posted 19 March 2020, 5:17 am EST
    Hi, guys.
    I have a problem when trying to pass data to Js Viewer with vue.js.
    bellow is my code , i can get data from server , but i have no idea how to pass data to the viewer.
    i don’t know how many errors with my code , because , i can’t find any full Vue.js demo from search webs .
    please help.
        Layout = null;
    <!DOCTYPE html>
    <html>
    <head>
        <meta name="viewport" content="width=device-width" />
        <title>report demo</title>
        <link href="~/lib/element-ui/theme-chalk/index.css" rel="stylesheet" />
        <link href="~/lib/element-ui/theme-chalk/display.css" rel="stylesheet" />
        <link href="~/css/scrollbar.css" rel="stylesheet" />
        <link href="~/css/site.css" rel="stylesheet" />
        <link href="~/AR/styles/ar-js-viewer.css" rel="stylesheet" />
        <script type="text/javascript" src="~/AR/dist/ar-js-core.js"></script>
        <script type="text/javascript" src="~/AR/dist/ar-js-viewer.js"></script>
        <script type="text/javascript" src="~/AR/dist/ar-js-pdf.js"></script>
        <script type="text/javascript" src="~/AR/dist/ar-js-xlsx.js"></script>
        <script type="text/javascript" src="~/AR/dist/ar-js-html.js"></script>
        <script>
            //GC.ActiveReports.Core.PageReport.LicenseKey = “YOUR_LICENSE_KEY”;
        </script>
    </head>
    <body>
        <div id="Viewer" style="height: 100vh">
            <ArViewer ref="arViewer"
                        language="zh"
                        v-bind:zoom="reportZoom"
                        viewMode="paginated"
                        v-bind:availableExports="['pdf','xlsx']"
                        v-on:report-loaded="onReportLoaded"
                        v-on:document-loaded="onDocumentLoaded"
                        :report="{ Uri: 'MarketSnapshot.rdlx-json' }" />
        </div>
        <script src="~/lib/jquery/dist/jquery.min.js"></script>
        <script src="~/js/site.js"></script>
        <script src="~/lib/vue/vue.min.js"></script>
        <script src="~/lib/element-ui/index.js"></script>
        <script src="~/js/jquery.cookie.js"></script>
        <script src="~/lib/axios/axios.min.js"></script>
        <script src="~/lib/crypto-js/crypto-js.js"></script>
        <script src="~/lib/jsrsasign/jsrsasign-all-min.js"></script>
        <script src="~/js/webApp.js"></script>
        <script>
        var vm = new Vue({
            el: "#app",
            components: {
                //ArViewer: ActiveReports.Viewer
                ArViewer: Viewer
            data: function() {
                return {
                    reportZoom: 50,
                    sidebar: false,
                    toolbar: true
            mounted() {
                this.getData();
            methods: {
                getData: function () {
                    this.$webApp.Get("GetJsonData", { year: 2020, month: 3 }, function (jsonData) {
                        debugger;
                        var viewer = vm.getViewer();
                        viewer.Open("@ViewBag.RptFile", { ReportParams: [{ Name: "data", Value: jsonData }] });
                onDocumentLoaded: function (a) {
                    console.log("document loaded", a);
                onReportLoaded: function (arg) {
                    console.log("report loaded", arg);
                getViewer() {
                    return this.$refs.arViewer;
    </script>
    </body>
    </html>
  • Posted 19 March 2020, 5:20 am EST
    the first problem is when i call vm.getViewer(); , this.$refs.arViewer; returns undefined .
  • Posted 19 March 2020, 5:53 am EST
    after some code change , i found the problem
    with the follow code
        <div id="app">
            <div id="Viewer" style="height: 100vh" ref="test">
                @*<ArViewer ref="arViewer"
                          language="zh"
                          :report="{ Uri: 'MarketSnapshot.rdlx-json' }" />*@
            </div>
        </div>
    Vue.js can’t parse it . so , $refs is empty.
    please tell me that what should be the right code here ?
  • Posted 19 March 2020, 9:01 am EST
    Have you tried with the following code:
    <GcArViewer ref="control"
                          language="zh"
  • Posted 19 March 2020, 9:07 pm EST - Updated 3 October 2022, 8:17 am EST
    still empty. see snaps.
  • Posted 22 March 2020, 4:30 pm EST - Updated 3 October 2022, 8:17 am EST
    As the ‘ref’ attribute is set to ‘control’, you need to use the same in the getViewer() method as below:
    getViewer() {
                    return this.$refs.control;
  • Posted 23 March 2020, 8:54 pm EST
    Hi, i think you didn’t understand what I talked about. I mean $ref is empty. It says that there was nothing could be parsed from the source code. Have you mentioned that?
  • Posted 24 March 2020, 1:15 am EST - Updated 3 October 2022, 8:17 am EST
    Sorry if I misunderstood. I re-checked and $refs is not empty at my end. Please see attached screen shot. I’ve also attached my application for your reference. Let me know if you get $refs as empty with the attached application as well.
    ArjsVueApp.zip
  • Posted 26 March 2020, 5:19 am EST - Updated 3 October 2022, 8:17 am EST
  • Posted 27 March 2020, 8:12 am EST
    I have checked with VueJs+ .Net Core 3.1 and found that $refs is not empty at my end.
    Could you please share your application so that I can check at my end.
  • Posted 27 March 2020, 8:30 am EST
    You can check with the attached sample and please let us know if you are able to replicate the issue at your end with the attached sample.
    VueDemoWithAsp.NetCore.zip
  • Posted 27 March 2020, 9:33 am EST
    Hi , Mohit . Thanks for reply. Does your code is created by .net core ? If so , you code maybe correct . And i said my project was create by Visual studio 2019 , asp.net core mvc application . and within my first post , what is the View code .
  • Posted 30 March 2020, 2:11 am EST
    Yes, I have created the .Net core application. Could you please share your own application so that I can look into the issue and help you accordingly. It will save time for both of us.
  • Posted 31 March 2020, 7:39 pm EST
    I’m on a business trip now。 i will post my code when i back to office.
  • Posted 1 April 2020, 12:26 am EST
    Thanks for the information and take your time.
    Stay safe :wink:
