Dynamically Creating Data Sets
Posted by: katie.koslosky on 13 September 2021, 11:25 am EST
    Posted 13 September 2021, 11:25 am EST
    “Using pre-defined data sources” overviews the process of creating pre-defined datasources & datatemplates using the Designer Desktop App. https://www.grapecity.com/activereportsjs/docs/DeveloperGuide/ActiveReportsJSDesignerComponent/Add-Predefined-Datasources-Datasets
    Is there a way to do this dynamically & programmatically in our JavaScript application?
    I can add the Data Source Connection Properties, but I’m hoping there is a way to programmatically call the 'Validate" functionality for a given Path in order to set dataset information without user intervention.
    ref.current.setReport({
                        definition: {
                            ...report.definition,
                            DataSources: [{
                                ConnectionProperties:{
                                    DataProvider: "JSONEMBED",
                                    ConnectString: "jsondata=" + JSON.stringify(data),
  • Posted 16 September 2021, 10:42 am EST
    Actually, I’m more or less successfully doing this. The only thing I would like to know at this point is if there is a way to make the dataset uneditable when opening them this way
        React.useEffect(()=>{
            if(data != null){
                console.log("data", data);
                console.log("data[0]", data[0]);
                console.log("JSON.stringify(data)", JSON.stringify(data));
                ref.current.getReport().then((report: ReportInfo) =>{
                    const keys = Object.keys(data[0]);
                    const fields = keys.map(key => ({
                        "Name": key,
                        "DataField": key
                        definition: {
                            DataSources: [{
                            DataSets: [{
                                Query: {
                                    CommandText: "jpath=$.*",
                                    DataSourceName: "Data"
                                Fields: fields,
                                AccentSensitivity: "Auto",
                                CaseSensitivity: "Auto",
                                KanatypeSensitivity: "Auto",
                                WidthSensitivity: "Auto",
                    setLoading(false);
        },[data]);
  • Posted 21 September 2021, 4:35 am EST
    Pre-defined data sets can be uneditable, but the code you shared sets the connection properties directly.
    The only way to make a data set uneditable for now is to hide the “Edit” button by using the corresponding CSS selector - you can inspect the designer UI in the browser and find it out.
